2000 Subaru Forester Slips Out of Gear
SUBARU
MARC ADAMUS
My 00' Subaru Forester, an automatic, seems to have started slipping out of gear when I accelerate through a sharp corner, followed by a jerk back into gear after briefly over-reving once the car is driving smoothly on the strait again. The car has 110,000 miles and recently had the cat. converter replaced and had a head gasket replaced quite a while ago. The engine light is not on, nor are any other warning lights. There may be some slight whining/whirring noise going on at times also.
Why does this always happen on a Saturday?.....
Apr 28, 2007 at 2:08 PM
2CARPRO JACK
  • 11,533 POSTS
Has a trans service ever been done? Sounds like the fluid level may be low or possibly the filter fell of. (Im not real familiar with Subaru transmissions)
Apr 29, 2007 at 1:36 AM
MARC ADAMUS
After checking, it looks like it's been more than 50,000 miles since the last transmission service was done.
Apr 29, 2007 at 12:08 PM
LOSTINMARS
  • 222 POSTS
you can try a service but i'd bet the trans is on the way out. wouldn't be surprised, i've seen plenty of them.
May 1, 2007 at 1:10 PM
Suggested Repair
Check the transmission fluid level and perform an overdue transmission service. If slipping continues, have the transmission diagnosed, as it may be failing.
Conversation Summary
A 2000 Subaru Forester automatic with 110,000 miles slips out of gear when accelerating through sharp corners, then jerks back into gear after briefly over-revving. There are no warning lights, and a slight whine or whir may occur. Experts suggested low fluid or a dislodged filter and noted the transmission service was more than 50,000 miles overdue. A service was recommended, but the transmission may be failing.
