93' Subaru Legacy, not starting. Alt/Fuel??
1993 SUBARU
RUJIKIN
93' Subaru Legacy; 130K; 4 cylinder. Since it has been getting cold out my car has been starting hard and wanting to die as I let it idle and warm up. It wasn't having any startup problems besides not wanting to continue idleing.Then a week ago my car refused to start up once, I thought it was an isolated incident as it didn't happen again till today. Now, the car is REFUSING to start. I have an engine code that points to the oxygen sensor, but I don't know if that could cause the car to not start. I'm thinking the problem is the alternator or the fuel pump(or some fuel system). Read next para
When I start up the car, it starts up like it always does and sounds the same for the first second. Then, it seems like it loses its initial starting power and just dies down from there. If I try it again afterwards it seems to not have much starting power and the same thing happens. I also hear the same stripping sound that occurs when you hold the key in the ignition position for too long. The belts seem to be in great condition so I doubt its them.
I really need to get this problem fixed soon. Thanks guys.
Nov 6, 2007 at 3:40 AM
This could be a fuel or igntion system problem.
Lets start by: When key is in On position do you hear the fuel pump come On for a few secs. If so do a fuel pressure check and comeback with the readings.
Nov 10, 2007 at 7:30 PM
RUJIKIN
I just took it to a mechanic and it seems the engine was flooded. He removed the spark plugs, let it dry, and says it works fine now. Says it happens in older cars often.
Nov 11, 2007 at 8:31 AM
Aren't you concerned what's making it to flood out- Yea the idea is good for a Carb system-but in EFI vehicles you don't have to do nothing just turn the key and it will fire up. You don't have to play around with the gas pedal for it to start.
Good Luck
Nov 11, 2007 at 9:38 AM
