1991 Subaru Loyale Timing Belt
1991 SUBARU
JBOTTO
My son's 1991 Subaru Loyale 4wd wagon has 124,000 miles and has never had the timing belt changed. He is a poor college student and can't afford to get it replaced right now. If the timing belt breaks on that model, will it ruin the engine as what happened with his Honda Accord a few years ago?
I was told that there was a notation on the "timing cover" that will indicate whether or not the breaking of the timing belt will interfer with operation of the engine, but we don't know where that is.
thank :| you!!!
Aug 7, 2007 at 4:24 AM
GREASE MONKEY
  • 23 POSTS
I think the factory says to replace the timing belts every 30,000 to 40,000 miles. If the belt's breaks it will not hurt the motor in that car. But why not replace them before they break and leave him on the side of the road in the middle of the night and then you have to pay a tow bill on top of the repair bill too!!
There are two belts on this car you need to replace the water pump while you are doing the belts too. It is right there and will not cost that much more labor while the belts are being changed out.
I hope I have helped you.
Aug 11, 2007 at 4:08 PM
Suggested Repair
Replace both timing belts and the water pump before the belts fail. The expert says a broken timing belt should not damage this engine, but waiting risks a roadside breakdown and a tow.
Conversation Summary
The owner of a 1991 Subaru Loyale wagon with 124,000 miles asks whether a never-replaced timing belt will ruin the engine if it breaks, and mentions a possible notation on the timing cover. The expert says the factory interval is about 30,000 to 40,000 miles, a broken belt should not hurt this engine, and both belts plus the water pump should be replaced before failure to avoid being stranded.
