1996 Subaru Impreza Tail Lights
JOHNBMURPHY
Electrical problem
1996 Subaru Impreza 4 cyl All Wheel Drive Manual 156K miles
1996 Impreza
2.2 liter
156,000 miles
Recently lots of rain, LOTS of rain
Literally, trunk became a small pool, could hear water sloshing around in the frame
Pulled rubber plug out of cavity in spare tire recess, water drained out
Drilled holes in underside of frame along door edge, water poured out
Reason for email:
Do not have tail lights. Fuse replaced, same size, new fuse does not blow
Connectors in the trunk, wet and dirty- they have been cleaned
Two fuses in fuse box under hood were blown, replaced w/same size, fuse for
light switch keeps burning out, very quickly, but, even then, do not have tail lights
for that short amount of time. – 10 to 15 seconds; and; fuse for dashboard lights is same fuse
Can anyone help
Oct 17, 2010 at 4:05 AM
LEGITIMATE007
  • 5,121 POSTS
hi, it sounds like when the harnesses in the trunk got wet, one or several of the the wires were damaged, you will need to get an ohm meter and test each of the pins in the harnass for resistence, there should be very little resistence, if the resistence is high on any one of those wires it will need to be traced. I know this is not what I would want to have to go through
https://www.2carpros.com/dia/how_to_use_a_voltmeter.htm
Oct 18, 2010 at 7:18 AM
