Codes P0172 and P0175, stumbles in park and at high RPM's
PALOMBA16
  • 17 POSTS
Just changed all fuel injectors and no change. It's got to be the pcm causing this. On a different I also have a 03 liberty and runs and drives fine, but pulling transmission codes. 1775, 870, 987 how many pressure switches on thus thing. 1 code says switch B and another switch E. The on on passenger side rear looks like its brand new and the 2 on the driver side are different sensors. Are these what I need to change the driver side sensors.
Wednesday, February 10th, 2021 AT 9:59 AM
  • 109,885 POSTS
I need to ask a favor. Can you copy and paste your new question to a new thread? We try to keep the threads specific to one topic. I hope you understand.
Wednesday, February 10th, 2021 AT 1:40 PM
PALOMBA16
  • 17 POSTS
My bad, done.
Wednesday, February 10th, 2021 AT 4:10 PM
  • 109,885 POSTS
No problem. Thanks for doing it.
Wednesday, February 10th, 2021 AT 7:24 PM
PALOMBA16
  • 17 POSTS
PCM reprogramming done and still no change. Still p0172 and p0175 and running bad. Could this all end up being a head gasket?
Friday, March 12th, 2021 AT 12:05 PM
  • 109,885 POSTS
Anything is possible, but you should be able to tell. You can either perform a compression test (link 1) or check the indicators in the second link below.
Friday, March 12th, 2021 AT 6:14 PM
PALOMBA16
  • 17 POSTS
I do notice that it smells of fuel bad. No leaks, but it's just running very rich. I just need to figure out why it's running so rich. New fuel injectors pump filter and regular all in one.
Tuesday, March 16th, 2021 AT 1:44 AM
  • 109,885 POSTS
If the fuel pressure is good and the injectors are new, do me a favor. Check the engine coolant temperature sensor's signal You will need a live data scan tool for this. If the sensor indicates an extremely cold temperature, it will cause a much richer fuel mixture.
Also, let me know what the short term fuel trims are.
Tuesday, March 16th, 2021 AT 6:34 PM
