2005 Jeep Liberty engine codes
75,000 MILES • 4 CYL • 2WD • MANUAL
SQUIR911
is there a way to check an engine light code with out buying anything or taking it in?
Jan 4, 2009 at 12:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, local auto part stores such as AutoZone, O'Reilly Auto Parts and Advance Auto Parts (to name a few) will all run a diagnostic scanner on your vehicle for free. This test will only work while the engine light is illuminated though.
Post the codes and we will help you out with fixing the issue.
Thanks for using 2carpros.com!
Jan 4, 2009 at 12:27 PM
