Stuck front passenger door
125,000 MILES • 4 CYL • FWD • AUTOMATIC
CANDO BROTHERS
The front passenger side door will not open from either side. it happened once before and someone got their arm in there messed with something and it came open. I have recently bought this car and the door has worked fine up until two weeks ago. I cannot get the door panel completely off nor do I have a lot of room to work or even see. all of the rods are hooked up and unbent everything feels and sounds as though it is working properly yet no matter what it will not open. The window goes up and down the door locks actuate properly and you can cycle the door lock with the key with no problems. Aside from painting it orange and putting a flag on the top and 01 on the door what do I do?
Aug 6, 2017 at 11:11 AM
  • 55,865 POSTS
It sounds like the lock rod fell off the latch so you cant unlock it. You will need to get the door panel off, Try to remove the seat first, this will help. Then lock for the lock rod to see if it is off the latch.
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Aug 7, 2017 at 9:26 AM
