I will attach pictures of codes
It was fine before I hooked up scanner now the steering is tight
Check the 80-amp EPS fuse #63 in the under-hood fuse panel and steering ground G207 on the lower left side of the dash. Verify power and ground at the steering control module. Disconnect the power steering motor, clear codes, and key on to see if code C056E returns. If power and ground are present and the motor test does not explain the fault, replace the steering control module.
A 2008 Chevrolet Equinox lost electric power steering assist and the steering became tight after a scan tool was connected and a steering relearn or test was attempted. The owner also reported service all-wheel-drive and tire-pressure warnings and asked about fuses, grounds, a floor-area wire, and a junkyard module. The expert advised checking the 80-amp EPS fuse #63 and ground G207, then testing power and ground at the steering control module. A bad column motor can shut the system down, so the motor should be disconnected and codes cleared before condemning the module. The expert said a scan tool itself would not disable power steering and that a failed steering control module can.
