Starts great, runs for a min then stalls
CHAVO2177
  • 33 POSTS
Good thing about this part is that its made by GM and from what I have read they are on some cavaliers. Just have to make sure the part numbers match!
Monday, January 6th, 2014 AT 6:54 AM
CHAVO2177
  • 33 POSTS
HAY Jacobandnickolas!
So I have an ICM on the way and once installed I will post a reply.
I also found a website that explained the ICM and what happens when they start to go bad. AND WOW! I had all those symptoms one thing that I remember it stateing is that if you keep it cold and dont allow it to get warm like with ice water it should run fine. So thats like one way to do a self test. However mine ws so far gone that I could not do that at all. This can only be done in the beginging stages.
Friday, January 10th, 2014 AT 8:35 AM
  • 109,885 POSTS
Let me know what you find.
Saturday, January 11th, 2014 AT 1:27 PM
CHAVO2177
  • 33 POSTS
Small update!
Put the ICM in last night. BUT DAMMIT. If the battery was not 100% Dead.
Wednesday, January 15th, 2014 AT 1:46 PM
  • 109,885 POSTS
Wow. You do have the same luck I do. Lol Let me know what you find when you get it started.
Thursday, January 16th, 2014 AT 5:33 AM
CHAVO2177
  • 33 POSTS
Well I wish that luck was on my side. BUT NO!
Got the new/used ICM in and the battery charged and it stalled again. I am a little more pissed today because this damn vehicle is just a Monster. So I told the shop to put a few more hours into it and let me know.
SHOP Repair #1. The shop told me that the ICM had power going into the ICM but was not coming out.
Fix #1. Replaced ICM with new/used one from FL.
Conclusion #1. Repair was a Fail still starts and stalls.
Thursday, January 16th, 2014 AT 6:38 AM
CHAVO2177
  • 33 POSTS
HELLO!
Latest update. As of 2-14-14. The shop told me that the ECM is Dead so I got a used one and they are now in the process of reprogramming!
I am almost at my wits end with this car!
Tuesday, February 18th, 2014 AT 8:12 AM
CHAVO2177
  • 33 POSTS
2-25-14.
Final fix!
So after everything is said and done it was the main computer and some burnt wires up by the fire wall.
The shop fixed the wires and tested the old computer before putting in a new one. So if any one else has this problem this is what it could be!
HAVE FUN TRYING TO DO IT YOURSELF AS THERE ARE SO MANY DIFFERENT THINGS THAT IT COULD BE!
Tuesday, February 25th, 2014 AT 7:31 AM
CHAVO2177
  • 33 POSTS
OK. I LIED!
The FINAL FIX was the crank or cam position sensor (cant remember what they said after I heard the bill!). After they got the new computer in and reprogramed they took it for a short ride and it stalled again. However this time the computer was working right and gave them a code to follow so after the got the code they replaced the sensor and now she runs like a champ again.
What this means is that for all you people out there that think they can fix something on your own you might be wasting your time because sensors go bad without sending codes or the codes get lost in a bad computer. My over all time spent was about 50+ hours of internet searches and attempted repairs I also dropped about $150ish into sensors that were not the problem and after all that I decided to take it to a shop and cost an additional $600. The shop I take it too is one I trust that has never done me wrong and everytime I go to this shop with a question they stop and listen and try to help. They have also done repairs for me that may have taken an hour or so and there was no charge.
So the moral of the story is YOU MAY TRY AND YOU MAY FAIL but after 50 hours and a $150 bucks take it to a shop! I am fortunate that I had another vechicle as my main vehicle because the was a year long process and a pain in the A$$.
Thursday, February 27th, 2014 AT 8:14 AM
CHAVO2177
  • 33 POSTS
7-7-2014. AFTER ALL THE TIME AND ALL THE INTERNET SEARCHES. I TRIED MANY DIFFERENT THINS TO FIX IT ON MY OWN AND ABOUT A LOT OF MONEY. FINALLY I GAVE UP AND TOOK IT TO A SHOP AND IT WAS THE CRANKSHAFT SENSOR. SO SAVE YOURSELF TIME AND MONEY AND TAKE IT TO THE SHOP, PUT IT ON THE COMPUTER AND BAM YOUR DONE!
Monday, July 7th, 2014 AT 11:20 AM
