Might not have an IAC valve, does it have a throttle cable? Drive by wire vehicles usually dont have them. Try removing the air intake boot and having someone hold the throttle wide open while you clean out around the butterfly with some carb spray and a rag, that might help stabilize the idle, if too much reversion has built up around it
SPONSORED LINKS
Friday, July 6th, 2007 AT 8:07 AM
