A bit more information please. What does it do when you try to start it with the key? Clicks? Nothing? Have you tried anything to fix the issue like testing the clutch interlock switch, the starter solenoid? Starter? Have you checked all the fuses to make sure the starting fuse and relay are good?
Please respond so we can help. Thanks.
Sunday, March 26th, 2017 AT 5:15 AM
