Starting issues 86 chevy celebrity 2.8l v6 2bbl carb.
180,000 MILES • 2.8L • V6 • AUTOMATIC
JO21716
Ok so it turns over but then immediately stalls out. The only trick to get it running is hold the key ignition turned for like 5 minutes while slightly stepping on gas. I have read it could be fuel pump, fuel filter, spark plugs and wires, rotors and caps.. all kinds of answers every where.. I also don't know where my fuel pump is located. I was told since its carbureted it wouldn't be in the fuel tank. Can you help me with these issues?
Oct 7, 2015 at 11:21 PM
HMAC300
  • 48,601 POSTS
due to age and alcohol in today's fuel this carb is problably the problem and needs to be rebuilt. if youwant to check fuel pressure it should be 3.5 lbs and about 1/2 pint in 30 seconds while cranking.
Oct 7, 2015 at 11:40 PM
JO21716
Thanks. I'll try that and get back to ya.
Oct 8, 2015 at 12:44 AM
