When I turn the key to crank the engine it keeps cranking?
150,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
JOSEPH WATSON
Engine keeps cranking.
Aug 15, 2022 at 9:12 AM
SQM
  • 6,383 POSTS
Generally speaking, you will need spark and fuel in order for the engine to start.
So, you will need to start by checking for spark and fuel.
When you turn the key to the on position, are you able to hear the fuel pump prime for a few seconds?
One way to tell if it is a fuel issue is to spray staring fluid into the intake and try to start. If the engine starts for a few seconds, then stops it will tell you that the engine is not getting fuel.
Take a look at this guide:
https://www.2carpros.com/articles/car-not-running-advanced
Let me know what you find or if you have any questions.
Aug 15, 2022 at 1:22 PM
JOSEPH WATSON
I'm having problems with ignition. truck starter keep cranking when trying to start truck..
Aug 15, 2022 at 6:45 PM
SQM
  • 6,383 POSTS
Right, if the engine is cranking but not starting, that means you are not getting spark or fuel. Have you got a chance to check the guide to further diagnose?
Aug 17, 2022 at 2:42 AM
