Starting hard with white smoke
123,507 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
FROG1961
When i go to start car hot or cold it does not start. When it finally starts white and a little black smoke pours out. Once running runs great.
Nov 19, 2017 at 4:45 AM
CARADIODOC
  • 34,414 POSTS
White smoke is a sign of burning engine coolant. To verify that, your mechanic can perform a chemical test at the radiator. That involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are present, the liquid will turn bright yellow.
Nov 19, 2017 at 9:10 AM
  • 110,248 POSTS
Also, check to make sure there is no coolant mixing with the motor oil. If it is, the oil will have a creamy tan color to it. One other simple test is this. When the engine is cold, remove the radiator cap and start the engine to see if any coolant comes out. If the system is pressurized by a head gasket, it will blow coolant out of the radiator.
Nov 19, 2017 at 9:32 AM
