That would depend on your luck.
There is a possibility the valves are not affected and installing the belt would do.
Check the valve clearances first, if any clearances are abnormally large, then the valves are bent and you would have to remove the head to replace the valves.
helpful?Yes
Monday, January 11th, 2021 AT 4:48 PM
(Merged)
