Cranks does not fire
175,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
AARON27
I have tried dry gas and after it sat for a few days. It was starting until one morning it did not start.
Dec 4, 2018 at 8:40 AM
  • 110,248 POSTS
There are several things that can cause a crank no start issue. However, most often it is related to loss of ignition spark or lack of fuel pressure. Here is a link that discusses the most common causes of this condition. Take a look through the link. It discusses what to check and how to do it.
Take a look at the things discusses and see if it helps. If it does not, let me know what you find and we will move on to the next step.
Dec 4, 2018 at 9:26 AM
