Starting
DAVIDK57
  • 2002 CHEVROLET TRACKER
  • 130,000 MILES
My 2002 tracker has always produced a large amount of corrosion at the batt terminals. So much so that at times it would not start. Cleaning has always solved this problem. Not this time. Bought a new batt still no luck could it be my cables?
Monday, April 29th, 2013 AT 10:37 AM
HMAC300
  • 48,601 POSTS
Yes it could just check where the positive ends and see if there is battery voltage there. If it's lower then the cables are to corroded. Of course there is always the possibility it is something else.
Friday, July 17th, 2020 AT 4:00 PM
