1999 Chevy Tracker WONT START
AKTAZZMAN
  • 1999 CHEVROLET TRACKER
  • 4 CYL
  • 4WD
  • MANUAL
  • 35,000 MILES
Wont Start Turns over has fuel (Pump and pressure regulator TEST Good) Coil Packs test good (distributorless) Crank Sensor test good, No spark, timing was checked twice and is good.
Saturday, August 8th, 2009 AT 5:53 PM
  • 109,896 POSTS
Was the check engine light on? Has the crank sensor been checked?
Friday, July 17th, 2020 AT 4:06 PM
AKTAZZMAN
Yes the crank and Cam sensor both tested good and the service engine soon light is not on. No codes loaded in the ECM either. NO spark at spark plug at all.
  • 109,896 POSTS
Are you getting power to the coil? If not, you need to trace the wires back to the ECM. THere has to be a broken wire if everthing else is good.
