Starter replacement instructions please?
INTERNETMECHANIC
  • 700 POSTS
Hey, no problem, have a good day.
Thursday, February 4th, 2021 AT 10:07 AM (Merged)
ALLENBRAD1987
Hi. I have a 2004 Chevrolet Blazer 4.3L, it's an extreme version, but I don't think that matters. Okay, here goes an issue I'm having now. Thought started went bad because it stopped working. But at same time my vehicle quit working while driving, it stalled out while idling first though, but the starter was bad after testing of it. Now I've replaced the starter. No luck. I don't know the problem and there is so many possibilities. When I turn key to on, nothing comes on on the dash but A/C and lights are working. But no power anywhere else. Also, the scanner things to tell you problems with your vehicle won't even power up when plugged in. I'm not a mechanic but I'm not slow. Someone please point me in the right direction. Thanks
Wednesday, August 4th, 2021 AT 1:27 PM
  • 52,797 POSTS
Good morning,
I would start with checking the battery. If you have low or no power that would explain the issue you have.
I attached some guides for you to follow below.
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Thursday, August 5th, 2021 AT 2:52 AM
