When warmed up while driving it stalls for a second then takes off again
MMPRINCE4000
  • 8,548 POSTS
Check the CV axle boots for rips/tears.
If OK, then check motor mounts/brakes and look for any loose shields under car.
Friday, April 19th, 2019 AT 11:05 AM (Merged)
MJR672
Maybe motor mount because noise stops when I cut the engine.
MMPRINCE4000
  • 8,548 POSTS
Could also be a tensioner assy, loose pulley.
MJR672
Thanks for pulley suggestion. Turned out to be a/c
pulley
MMPRINCE4000
  • 8,548 POSTS
Good news! Thanks for using 2carpros.
MARK WICHMAN
  • 1999 PONTIAC GRAND PRIX
  • 3.8L
  • V6
  • FWD
  • 150,000 MILES
Bought car at auction had to get code key made do the thirty minute program. Car started but wanted to die. I left jump pack on it to drive home it ran fine. Now first start of day it starts fine put in gear it moves, but after sixty seconds I hear it is drain/drop in power and idle and dies. Go to restart it and wont unless I work pedal after a few it will at times idle on own, but surges or dies. Using two feet wont even help when it is put into gear dies no matter what. What the issue the coded key and anti theft?
HMAC300
  • 48,601 POSTS
The key has to be coded to the car the only way to code a new key is if you have an original one.
Friday, April 19th, 2019 AT 11:06 AM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
  • 127,000 MILES
I recently purchased my GTP and fell in love with it, however the car got to a point where it would hardly drag itself into the drive (no exaggertain) I took it to a local shop and they did a complete tune up of the car. The thing ran great after that. Recently I noticed that the car with cut out when going up a hill but then be just fine when either A.) I gave it more gas or B.) It was done going up the hill.
Well the other day I go into that gas station and left the car running, when I came back out the car was barely running and it was spitting and sputtering then it died. It would start back up then die again, it took 20min to home when I live just 3 blocks away. I have gone back out to start it and it fires right up but when I go to give it gas it cuts out again, doesnt die just cuts out. What could be wrong with this thing?
  • 52,797 POSTS
Is the check engine light on?
Have the fuel pressure checked while the situation happens.
Check for spark
LORIHS4
  • 6 CYL
  • FWD
  • 150,000 MILES
What would cause my 99 Grand Prix GT to completly die while I'm driving? It does not matter if I'm driving 30 mph or 80 mph. I have to pull off the road and turn car off and wait a few minuets. It will then start back up and either stay running or it will start and then as soon as I put it into drive it dies again. Please HELP!
MMPRINCE4000
  • 8,548 POSTS
Have ignition module tested, if PCM does not get an ignition reference, it will shut off fuel.
CMODS1
  • 146,000 MILES
My car stalls out at stop and starts right back up and is fine. And has all its power. Replace IAC and cam postion sensor and does it more when it is hot. And after getting gas and it sometimes idles up and down and than dies.
HMAC300
  • 48,601 POSTS
Clean throttle plate on both sides with choke cleaner and iac hole. Also check for a vacuum leak, like holses in hoses/lines off etc.
2CP-ARCHIVES
  • 4,540 POSTS
  • 153,000 MILES
What makes a battery light come n then the car dies not won't start back up I have fuel n spark
  • 110,068 POSTS
Usually a bad alternator. However, if you can, take the car to a parts store and have them load test the battery as well as check the alt for output. Most will do it for free and then you will know where the problem is.
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
