Stalling when I slow down
1995 BUICK LESABRE
172,931 MILES • 3.8L • V6 • 2WD • AUTOMATIC
TIMMY WARREN
It happens often at least almost every time when I slow down to a stop the car will die and then I put it in neutral and it starts right back up and put it in drive but it doesn't do it when I consistently stay on the gas what could be the issue?
Mar 18, 2022 at 8:42 AM
  • 55,433 POSTS
This sounds like a vacuum leak, or you have a dirty throttle bore. here are some guides to help you fix the problem:
https://www.2carpros.com/articles/stall-at-idle
and
and
Mar 19, 2022 at 9:44 AM
