Stalling after twenty or thirty minutes
NICKSIDEAS
  • 2000 DODGE DAKOTA
  • 4.7L
  • V8
  • 200,000 MILES
When cold starts right up, after twenty or thirty minutes the truck sputters and stalls will not start again for twenty or thirty minutes. I have replaced the crank, cam, idle and throttle sensors. It is getting fuel.
Tuesday, December 5th, 2017 AT 3:57 AM
CARADIODOC
  • 33,967 POSTS
First check for spark when the no-start occurs. Also, listen for the hum of the fuel pump for one second when you turn on the ignition switch. If you can hear that, you are going to have what appears to be good fuel pressure, but if you are just looking at some spray from the test port, that is not a valid test. You need to verify the pressure is correct with a fuel pressure gauge. Running for that one second is why fuel pressure looks okay, but it's more important to know if the pump resumes running during cranking. If you do not have spark, chances are pretty good the fuel pump is not running either.
Have you read the diagnostic fault codes? If not, what led you to the throttle position sensor? What idle sensor are you referring to?
Tuesday, December 5th, 2017 AT 12:39 PM
