2000 Dodge Dakota Engine dies
140,000 MILES • V8 • 2WD • AUTOMATIC
BECKDJAMES
  • 5 POSTS
I will be driving down the interstate, @65mph, and the engine will dies. When I pull of to the side of the road, I have to let it set for about 10 minutes before it will start. The strater will work, but it will not turnover. Also, when it idles, it will race.
Apr 15, 2009 at 8:52 AM
  • 110,251 POSTS
Has the check engine light ever come on? Also, when the truck doesn't start, is it possible for you to check to see if fuel or spark is missing? Most likely, one will be missing.
Let me know what you find.
Apr 16, 2009 at 1:30 PM
BECKDJAMES
  • 5 POSTS
The check engine light does not come on. It also happened again today. Without warning, cruising at 65 MPH, the engine just died. it took about 10 minutes before the engine would start. Being on the side of the interstate, I could not tell if the fuel or spark was missing.
Apr 16, 2009 at 1:59 PM
  • 110,251 POSTS
Carry an extra sparkplug with you. If it dies, plug it into a wire and see if there is spark. If the check engine light isn't coming on, chances are it is fuel related, but at this point, it is a process of elimination. We need to start somewhere.
Apr 17, 2009 at 7:21 AM
BECKDJAMES
  • 5 POSTS
Today I thought I heard a pop before it started losing power and died.
Apr 21, 2009 at 12:23 PM
  • 110,251 POSTS
Is the pop from under the hood or from the exhaust?
Apr 21, 2009 at 12:36 PM
BECKDJAMES
  • 5 POSTS
I think it came from under the hood.
Apr 21, 2009 at 1:19 PM
  • 110,251 POSTS
I hate to say it, but the only to determine what is going on is to identify if there is a loss of fuel or spark. The only suggestion I can think of other than that is a MAP sensor. The problem is, I can't be sure without a check engine light coming on and I hate to have you spend money on something you may not need.
Apr 22, 2009 at 4:57 AM
BECKDJAMES
  • 5 POSTS
I was incorrect, the check engine light is on. For some reason I thought it was something else.
Apr 22, 2009 at 6:10 AM
