Sometimes wont start.
148,000 MILES
BUFFEDTWO
Just resently started to have problems with my Bonneville starting up right away. After several tries I would wait a couple of minute athen it would start but after a back fire. Then when driving the car would start to hestiate and then cut off. It would start up again and then run fine. What could be causing this. My mechanic just changed my crankshaft sensor. But the problem still happens. But not all the time.
Apr 24, 2013 at 12:33 AM
JDL
  • 16,098 POSTS
Intermittent issues can be hard to track. You have to do some testing when the problem is ongoing. When the problem occurs, if it cranks good but won't start, have a helper crank it while you visually check for spark at the plugs. Go from there.
Can you check for applicable trouble codes? To check for codes, yourself, at the least, you need an obd2 code reader. Some of the national brand autostores will check codes for free, if a code sets.
Apr 24, 2013 at 1:25 AM
