2000 Pontiac Bonneville Bonneville Wont start
RCTACH
  • 2000 PONTIAC BONNEVILLE
  • 6 CYL
  • FWD
  • 70,000 MILES
Hi I have a 2000 Pontiac Bonneville that sat for 2 months with battery removed. The car started and ran fine before parking it for body repairs. The engine will hit like it is going to start on first or second crank but nothing after that. The battery was charged several times and the key was turned on while the battery was charging (many lights flashed on/off before shutting the key off). 40LBS fuel pressure on rail, Security light stops flashing and goes on steady when key is inserted in the ignition. Havent been able to check for code.
Monday, November 2nd, 2009 AT 12:36 PM
  • 109,885 POSTS
Does the light stay on when you crank the engine? If so, take it to a dealer. The security system has shut down the engine and they are the only ones that have the proper test equipment to diagnose the problem.
Wednesday, December 16th, 2009 AT 11:46 AM
