Soft brakes after replacing the front calipers?
213,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMYBELL614
  • 11 POSTS
I have the car listed above LE. I replaced the front calipers then bled the brakes (rear right, rear left, front right, front left). While bleeding the brakes, the pedal was firm, after I bled all the brakes and turned the car on the pedal goes all the way to the floor. Is there another reason this could be happening other than there being air in the system? (No leaks are coming from the master cylinder) When I bleed the brakes is there a sure way to know that all the air is out?
Dec 14, 2022 at 6:08 PM
  • 55,721 POSTS
Yep, there is air trapped inside the ABS controller which is common. You will need to bleed the brake with the ABS control valve open which is done by using a scanner. This video and guide will show you what to do:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://youtu.be/nQRnKyVyMuQ
Dec 15, 2022 at 7:06 AM
