Have intermittent squealing or squeaking noise coming from one front end wheel/brake.
28,000 MILES • 4 CYL • FWD • AUTOMATIC
LGOTSCH
Have intermittent squealing or squeaking noise coming from one front end wheel/brake. Doesn't do it all the time but when it happens, it does it at all speeds, and in all weather and road conditions. Noise stops when brakes are applied or when making a turn. Have had brake pads and brake components checked by Toyota, no problem found. May be coincidence but problem seemed to start after the tires were rotated.
Any suggestions?
Jun 1, 2009 at 9:49 AM
BILLYMAC
  • 2,204 POSTS
hi i would have the rotors turned.the toyota techs measured the brake rotors and miked everything out and all were in specs.so they would not reccomend repair.s because they will not rec repairs for vehicle enhancement. however you obviously are tired of the phantom import brake squeal. so to stop the annoying noise turn the rotors and it will go away for now. thanks billymac
Mar 5, 2021 at 3:30 AM
