1986 Toyota Camry brakes locked
KEVEKEV
  • 1986 TOYOTA CAMRY
Brakes problem
1986 Toyota Camry 4 cyl Front Wheel Drive Automatic
i changed pads in the front and bought a new caliper for the front drivers side but the car will not move it is like my brakes are stuck or locked
Wednesday, December 3rd, 2008 AT 1:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Jack front of vehicle up and support and scotch. Have assistant put vehicle in neutral. With vehicle in neutral, try spinning front wheels by hand, if you feel resistance then brakes probably need bleeding.
Wednesday, December 3rd, 2008 AT 1:37 AM
Inspect the brake hose on it if clogged/collasped-if okay open bleeder screw and compression the caliper piston till its flush put it back together and see what happens-
Wednesday, December 3rd, 2008 AT 1:38 AM
