2003 Toyota Camry brake calipers and brake noise
104,000 MILES • 4 CYL • FWD • AUTOMATIC
MAYUKHEE
when I push the brake it makes a friction noise, I have changed my front brakes recently and also have done all the servicing necessary with the brake flush, brake fluid change etc. but still it keeps on making the noise.
Apr 19, 2010 at 12:56 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Did you get the rotors surfaced and what type of pad did you install? did you use a brand pad or did you go get a cheap set?
Mark (mhpautos)
Apr 19, 2010 at 1:02 PM
MAYUKHEE
I am not sure about the brand, but in the bill the mechanic wrote about servicing the rotor. do U think I can have some problem with my rear brake, I have serviced the front brake, they didn't tell me anything about the rear brake
Apr 19, 2010 at 1:07 PM
  • 31,937 POSTS
Hi there,
If the rears have not been checked out, i would be doing that, and ensure that the rotors were surfaced and quality pads installed as cheap pads will make a lot of noise.
mark (mhpautos)
Apr 19, 2010 at 1:09 PM
MAYUKHEE
which brand do u recommend for the brakes? also which car car center should I take my car for repairing in future? I live in South Carolina and I have AAA membership.
Apr 19, 2010 at 1:12 PM
  • 31,937 POSTS
I use only genuine brake components, you pay a little more but you get the quality, as for a work shop, that i can't help you with as i live in Australia.
Mark (mhpautos)
Apr 19, 2010 at 1:20 PM
MAYUKHEE
I really need to find a good mechanic
Apr 19, 2010 at 1:22 PM
  • 31,937 POSTS
I would try and contact AAA as they may have a list of recommended repairers in you district.
mark (mhpautos)
Apr 19, 2010 at 1:31 PM
MAYUKHEE
thank you
Apr 19, 2010 at 1:33 PM
  • 31,937 POSTS
Thank you for using 2carpros, you feed back is welcome, feel feed to re post if you have any further problems.
mark (mhpautos)
Apr 19, 2010 at 1:42 PM
