K1500 Z71. Owned for six years. Brake pedal has always been soft. When stopping I always pump once half way and then step on pedal to brake. If I push hard I can make ABS go off. Decided to bleed brakes and broke off bleeder screw on caliper so replaced both front calipers and pads. Rear pads were fine. Bled system. Brake fluid was dark so bled until fresh fluid came through bleeders beginning with passenger rear, driver rear, passenger front, ending at driver front. Rear brakes and wheel cylinders inspected for leaks. All good. Brakes were still soft. With vehicle not running pedal is firm. Start vehicle and they go to the floor. Unplugged brake lines from master cylinder and installed plugs. Stepped on brake pedal with moderate pressure and hard as a rock. No movement other than pedal free play.reinstalled lines and bled system. Still soft pedal. checked rear drum adjustment and they were needing spread out quite a bit. So I adjusted them to two clicks in from not being able to turn drums by hand. Still soft peddle. So I broke the rules and got rubber fuel line and three clamps and clamped the rubber brake lines at each caliper and at the splitter for the shared rear line. Started vehicle and pedal is hard as a rock. Released rear clamp and pedal went to floor. Put rear clamp back on. Nice and firm again. Took off front driver clamp and went to floor. Put it back on and firm again. Same with passenger clamp. What am I missing?
Nov 2, 2018 at 1:57 AM
