Brake pedal goes to floor
190,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
HURLER61
My brake pedal started going to the floor. I replaced master cylinder twice. New calipers, wheel cylinders, new brake lines. I bench bleed master cylinder.
Started in rear bled and bled until pedal was firm. Please note I have done this
many many times and never had a problem. Pedal firm push down real hard pedal firm. start truck then pedal goes to floor. Remove vacuum hose from booster and the pedal gets firm.
Thanks
Dec 9, 2016 at 3:34 AM
HMAC300
  • 48,601 POSTS
have a mechanic use his scanner to bleed brakes he can command valves open so they can be bled probably air in ABS unit. You can try a power bleeder to do this sometimes successful other times not. when you disconnect vacuum booster it is just like having engine off when parked.
Feb 22, 2021 at 9:29 AM
STEVE W.
  • 15,404 POSTS
If I am reading this right the pedal is good with the engine off, but when running it drops on its own. That sounds like a failing internal booster valve. It is allowing vacuum to draw the diaphragm down. Have seen that happen a few times.
HURLER61
Inside the ABS unit?
HMAC300
  • 48,601 POSTS
yes, inside the ABS unit.
