1998 Chevy Silverado Front brakes
JEFFSORR
  • 1998 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 100,000 MILES
My brake pedal is hitting the floor when trying to stop. Pumping the brake pedal does not help. COuld the front brakes need changing? If so, is there special notes or tips for changing the front brakes?
Monday, December 28th, 2009 AT 1:34 PM
DOCFIXIT
  • 18,828 POSTS
Check master cylinder fluid level. If good then failure of master cylinder internal seals is fault
Monday, December 28th, 2009 AT 1:41 PM
JEFFSORR
Thanks very much. So the primary issue for the brake petal hitting the floor is master-cylider related and not an issue with the front brakes? I know that I have had to change the front brakes on this truck at least every 20k miles as they go through them kinda quickly. I know its been about 20k since the front brakes were changed and figured the problem was with the front brakes.
Monday, December 28th, 2009 AT 1:46 PM
