2007 Ford Mustang SJB Wiring Issues
These are all 8 connectors, diagrams (1,2connector A) go together- (3,4connector B)- (5,6connector C)- (7,8connector D)- (9,10connector E)- (11,12connector F)- (13connector G) - (14,15connector H)
There is a diagnostic Flow Chart if there the SJB has no communication with a scan tool.
It can be used with a ELM327 OBD2 adapter and I believe the software is free. It's a good option to have if other scan tools sometimes don't work in certain situations.
And so far, the 4.0L and the 4.6L are exactly the same Body Control Module, all the same connectors and pinouts. I'll check the 5.4L as well.
https://forscan.org/home.html
Here's the network topology just in case you need it.
Do you have comms with the SJB?
Suggested Repair
Treat this as a harness and connector problem before replacing the Smart Junction Box. Inspect all SJB connectors for loose pin fit, corrosion, and water intrusion in the right kick panel, and repair broken wires found by the wiggle test. Check solder joints at the connector pins if the module is opened, then pull system-specific codes with FORScan or IDS to narrow the circuits. Confirm the wiring is sound before programming a replacement module, since security programming can be complicated.
Conversation Summary
The owner of a 2007 Ford Mustang asked for Smart Junction Box connector diagrams, pinouts, and interchangeable modules for part 7R3T-14B476-BG. Multiple accessories, the turn signals, A/C clutch, and ECU power act up, and wiggling the front harness can cut power to the ECU. The expert identified the SJB as a body control module on the medium-speed CAN bus, posted connector diagrams, and advised checking pin fit, cracked solder joints, moisture, and corrosion. The owner found at least one broken left-blinker wire in the harness. Aftermarket diagrams for the 2007 4.0, 4.6, and 5.4, and the 2008 4.6, show the same connectors and pinouts, but no service part number was found. The expert recommended verifying every related wire and pulling codes before programming another security-related module.
