1995 Ford Mustang Intermittent No-Start
BIGLUCKEY
  • 6 POSTS
mt 1995 ford mustang 3.8L has a problem statrting i have replaced the coil-pack the comp. the crank-position sensor the ign. module and the problem still continues the only way i can start the car is to take the neg. post of the battery for 5-10 sec, then it will start with no problem but if i park it for a couple of days i have to do the same thing again
Apr 8, 2007 at 6:16 AM
MERLIN2021
  • 17,250 POSTS
What happens when it won't start? Does it crank? Or is it dead? You may have answered your own question...try changing the Neg battery cable. It may not be grounding to the engine block sufficiently...
Apr 9, 2007 at 4:19 AM
BIGLUCKEY
  • 6 POSTS
[quote:f9fd67aa19="merlin2021"]What happens when it won't start? Does it crank? Or is it dead? You may have answered your own question...try changing the Neg battery cable. It may not be grounding to the engine block sufficiently...[/quote:f9fd67aa19].IT TURNS OVER AND CRANKS SOMETIMESMAYBE FIVE OR SIX TIMES BUT IF I GO OUT THE NEXT MORNING IT MAY CRANK OR JUST TURN-OVER UNTIL I RESET THE NEG. CABLE
Apr 9, 2007 at 5:48 AM
MERLIN2021
  • 17,250 POSTS
The other thing is...because it's a 95 it's ODBI so you are clearing any stored codes every time you pull the cable for 10-15 sec...Try and see if there are a few codes next time!
Apr 9, 2007 at 7:09 AM
BIGLUCKEY
  • 6 POSTS
[quote:f5e3fbd905="merlin2021"]The other thing is...because it's a 95 it's ODBI so you are clearing any stored codes every time you pull the cable for 10-15 sec...Try and see if there are a few codes next time![/quote:f5e3fbd905] HOW DO I DO THAT THE CHECK ENGINE LIGHT ON THE DASH IS NOT ON
Apr 9, 2007 at 8:05 AM
MERLIN2021
  • 17,250 POSTS
Does it come on when the key is in on engine off position? If so it means the self test system works.
It may not have a code, cause it keeps clearing when the neg cable is removed...Replace the neg cable yet?
Apr 9, 2007 at 8:16 AM
BIGLUCKEY
  • 6 POSTS
[quote:6c681f4344="merlin2021"]Does it come on when the key is in on engine off position? If so it means the self test system works.
It may not have a code, cause it keeps clearing when the neg cable is removed...Replace the neg cable yet?[/quote:6c681f4344] no it statrs like any other normal car its just doesnt turn- over eveytime so times it will sometimes it wont unless i take the neg. cable off,i am so sorry i meant to say that yes if i turn the key forward it will come on then on the dash but not when it's running normal. do you think the neg cable could be the problem , thanx in advance
Apr 9, 2007 at 8:18 AM
Suggested Repair
Replace the negative battery cable and confirm it grounds solidly to the engine block. Before disconnecting the battery again, retrieve any stored OBD-I codes, since removing the cable clears them.
Conversation Summary
A 1995 Ford Mustang 3.8L cranks or turns over intermittently and often will not start until the negative battery cable is disconnected for several seconds. Coil pack, computer, crankshaft position sensor, and ignition module were already replaced. The check engine light comes on with the key on and engine off, but not during normal running. The expert advised replacing the negative cable for a possible poor ground and reading stored codes before the battery disconnect clears them.
