Was wondering how i can fix this. If i need a new starter or if the key was bad. Even tho both of my keys didnt work :(
Aug 22, 2006 at 7:04 AM
Suspect a bad ignition switch. Have a locksmith repair the tumblers, or replace the ignition switch and lock assembly.
The owner of a 1988 Ford Mustang reports that the key will not turn and that both keys fail. The expert suspects a bad ignition switch and suggests having a locksmith repair the tumblers or replacing the switch and lock assembly.
