Small coolant leak
1990 CADILLAC DEVILLE
150,000 MILES • 4.5L • V8 • 2WD • AUTOMATIC
WYATTPHELPS
I have a small coolant leak coming from the driver side front of the engine bay, it looks like right where the radiator would be but it’s hard to tell there’s some shrouding in the way. I haven’t been able to take it off and look yet. This only happened last night but I would like to know some likely possibilities. Side note, the leak is new I had a dead battery in the car for about a month and it was sitting for that period of time and it started leaking one I started it back up.
Dec 28, 2018 at 10:26 AM
PATENTED_REPAIR_PRO
  • CERTIFIED EXPERT
  • 1,853 POSTS
The best way to go about this is to rent or borrow a cooling system pressure tester and with the engine cold, top off the cooling system with water, then screw on the pressure tester, pump the cooling system up to like 15 psi, then look for the leak. It should be a lot easier to find since the pressure is going to make the leak larger.
Dec 28, 2018 at 10:51 AM
WYATTPHELPS
Okay this may be a dumb question, but there should be instructions on how to use that right? I’ve never used one before.
Dec 28, 2018 at 11:03 AM
PATENTED_REPAIR_PRO
  • CERTIFIED EXPERT
  • 1,853 POSTS
The kit should have instructions but basically you screw the tester on in place of the radiator or degas cap, then pump the handle until the gauge reads 15 psi.
Here is a link explaining the procedure: https://www.2carpros.com/articles/radiator-pressure-test
Dec 28, 2018 at 11:20 AM
WYATTPHELPS
Thanks.
Dec 28, 2018 at 11:37 AM
PATENTED_REPAIR_PRO
  • CERTIFIED EXPERT
  • 1,853 POSTS
You are welcome.
Dec 29, 2018 at 6:56 AM
