Thanks for your help!
RCH
Stripped Northstar head-bolt threads do not require a new engine. Remove the engine and heads, then install Time-Serts in the block threads. While apart, reseal the case halves and replace the lower oil pan gasket and rear main seal. A GM remanufactured engine is a reasonable alternative if the car will be kept and the budget allows.
A 1998 Cadillac Deville with a 4.6L Northstar was losing coolant and needing frequent top-offs. After water-pump, manifold, and thermostat-gasket work and pressure tests, the shop said stripped head-bolt threads were letting coolant enter the exhaust and that only a new engine would fix it. An expert said the engine must come out and the heads be removed so Time-Serts can restore the block threads, and recommended resealing the case halves and replacing the lower oil pan gasket and rear main seal while it is apart. A GM remanufactured engine was also suggested if the owner plans to keep the vehicle.
