Does not start, engine turns over slowly then stops
125,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
WAYNESRAGE
  • 12 POSTS
Bought car from insurance auction. noticed timing chain was loose and wasn't able to turn engine with plugs in. inspected valves, replaced timing chains, and starter. car turns over slowly then stops, then can try to crank again and same thing. put a booster on it and when the battery had 13.2 volts it would spin over decent and attempt to start then voltage would drop to about 12.3 volts possible ground issue? Something I'm overlooking?
Update: replaced ground car turn over better and tries to start but wont ever start.
Feb 26, 2021 at 1:31 PM
WAYNESRAGE
  • 12 POSTS
Third update: car now starts guessing hiccup in communication or fuel issue from sitting, unplugged ECM for a few minutes then plugged back in. was a rough start at first but fired up and smoothed out.
Feb 27, 2021 at 5:12 AM
  • 110,248 POSTS
Have you repaired the vehicle? If not, what is happening at this point?
Take care and God Bless,
Feb 27, 2021 at 11:42 AM
WAYNESRAGE
  • 12 POSTS
Yes, vehicle starts every time no hesitation now. guess it had its quirks to go through from sitting at the car auction so long.
Feb 27, 2021 at 8:08 PM
  • 110,248 POSTS
That's great news. I'm glad to hear it. Please feel free to come back anytime in the future if you have questions.
Feb 28, 2021 at 8:40 AM
  • 55,676 POSTS
It could have a low battery. I would follow this guide to confirm the failure:
Feb 28, 2021 at 10:55 AM
