While driving transmission goes into neutral
100,000 MILES • 4WD • AUTOMATIC
JCVASQUEZ
While I am driving it goes in to neutral and I have to shut it off and wait for a little bit then it will drive again. And it is running at hi rpm's. People are telling me the transmission is bad and others said to replace the shift solenoids.
Aug 1, 2019 at 1:45 AM
  • 55,732 POSTS
It could be the shift solenoids which are common, I need to ask if you checked the fluid level and do you have a check engine light on? Here are two guides to help get us started.
and
Aug 2, 2019 at 6:13 AM
