2001 Chevy Tahoe Help please
BIGCOUNTRYBR
  • 2001 CHEVROLET TAHOE
  • V8
  • 4WD
  • 106,000 MILES
Gentlemen-
I currently own a 2001 chevy tahoe 106k. Just recently it has started to lag while shifting gears. Especially in the first three if I go slow. When it gets to where it would normally shift it rev’s almost like it doesn’t have enough torque to switch gears. If I stay on the acceleration pretty hard I cannot notice it, but when I make a 90 turn on a corner 10-20mph and then I give it gas it almost like it was never in gear. Any help would be greatly appreciated. The only two things I can guess is either my tranny is about to go to spiltsville or maybe my torque converter is bad.
Monday, February 9th, 2009 AT 9:24 AM
DOCFIXIT
  • 18,828 POSTS
Is fluid level good? Has the fluid and filter been changed in the 106k miles? If this is all good then trans needs to be on a scanner to check speed sensors and shift solenoids operation.
Tuesday, February 10th, 2009 AT 10:54 AM
BIGCOUNTRYBR
Fluid level checked out fine. Changed the fluid and filter at 93k when it was previously giving me problems and it worked itself out. Now that I just typed that I realized that it's time to change it again or at least the filter (every 12k-15k.)
I just replaced my knock sensors (under the intake manifold) two days later my water pump went and thats when it began to be noticable, especially around turns.
When I got in home that night it leaked out a whole lot of coolant, which at first I thought was tranny fluid. With the water pump replaced it still does it. Would one have anything to do with the other? Do I need to drive it and see if it'll adjust?
I'm trying to fix/make sure it's not something else before I take it to a tranny shop and they want $1500 to service it.
I really appreciate your help. Thank you.
Tuesday, February 10th, 2009 AT 4:48 PM
DOCFIXIT
  • 18,828 POSTS
Faulty speed sensors or shift solenoids can cause late shift. That is why a scanner is necessary to check there operation.
Tuesday, February 10th, 2009 AT 4:59 PM
