Shifting problem and loss of power?
155,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
BIG DEAN
When I drive from a stop and give gas to go it winds up and not fast it won't change into 2nd gear until I let off the gas and it then is not moving very fast. When I go to kick it down to gain speed it barely will get up and go. What problem do you think I have? My thought is it's the TCM. What are your thoughts? Can you help me? thank you
Sep 11, 2022 at 11:19 PM
  • 55,782 POSTS
It could be but it sounds more like you have a clogged exhaust system which will cause low power and late shifts, to find out for sure follow this guide which can let you know if the catalytic converter is bad:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Also, we should run the codes to see what comes up. You can get a code scanner from Amazon for about $20.00.
Here is a guide/video to show you how:
Here is a scanner link:
https://amzn.to/3Qi1SS6
Let me know what you find so we can get the problem fixed for you.
Sep 12, 2022 at 5:13 AM
