Shifting in and out of gear while driving at normal speeds
260,000 MILES • 5.0L • V8
JASON2013
When driving on the highway at 65 mph it shifts in and out of overdrive. When I take off from a stop it winds out and slams into gear and if I try to start out in second gear it stalls sometimes and it stays revved up at 2000 rpm while stopped.
Aug 21, 2018 at 9:35 AM
  • 55,682 POSTS
This sounds like the fluid level is low or the transmission filter has fallen of inside the transmission pan. Here is a guide to help us get started finding out the problem:
Cheers, Ken
Aug 23, 2018 at 3:27 AM
JASON2013
Hey Ken, Jason here. I changed the filter and fluid in the transmission did not seem to help matters any. It kept having the same problems I was still driving it being it is my only transportation. I noticed the gauges and other electrical issues happening so I changed the computer (ECM) and everything worked out and runs great, except for when I first take off from a stop it seems to still be sluggish for a bit. Any further ideas? I am stumped.
Aug 27, 2018 at 5:01 AM
  • 55,682 POSTS
It sounds like the transmission issue is solved? If so nice work, if you have a new issue now lets start a new question. Please post your new question here, you must be logged in.
Cheers, Ken
Aug 28, 2018 at 3:01 AM
