1992 Ford Bronco idle increasing
179,000 MILES • V8 • 4WD • AUTOMATIC
SKIPBOND
  • 7 POSTS
when ever I put my Bronco from park to rev or drive upon starting the idle accelerates upwards to 1500 rpm during the moving of the gear shift. and yes I've checked to see if my foot is the problem. LOL any help thanks guys.
Jan 22, 2009 at 10:01 PM
BLACKOP555
  • 10,386 POSTS
it is supposed to rev up a little bit to prevent it from boggign and dieing.
what you can try to do first is remove the negative battery cable for about 10 minutes, then reattatch and see if the problem goes away.
Feb 16, 2009 at 1:21 AM
