2008 Chevrolet Equinox Serpentine Belt Fix
200,000 MILES • 3.6L • 6 CYL
ANTAINE
I was asked to help with an alternator change, but they had cut the belt off before I got there, and it looks like it goes around a lower motor mount but I'm unsure. it's a Sport model.
Jul 23, 2023 at 10:54 AM
ANTAINE
The 3.4 and 3.6 have different placements and I can't find any info other than the diagram for 3.6.
Jul 23, 2023 at 11:02 AM
  • 110,251 POSTS
If you are working with a 3.4, you are correct. The routing is different. If you look below, I attached the belt routing diagram for the 3.4L, take a look at it and let me know if that is what you needed.
I don't know if you need it, but here is a link you may find helpful:
https://www.2carpros.com/articles/replace-serpentine-belt
Let me know if this helps.
joe
See pic below.
Jul 23, 2023 at 2:04 PM
ANTAINE
I'm working on a 3.6 and all I can get for it is the pattern. Just don't know if I have to take off a lower motor mount that seems to be between the pulleys.
Jul 23, 2023 at 9:08 PM
  • 110,251 POSTS
On the 3.6L, the engine mount bracket on the right-side needs removed for the belt.
If you look below, I attached the directions for you. Also, the belt routing for the 3.6L is included in the directions.
Let me know if this helps or if you have questions.
Jul 24, 2023 at 2:01 PM
Suggested Repair
On the 3.6L, remove the right-side engine mount bracket to install the serpentine belt, then route the belt using the 3.6L diagram included with the service directions.
Conversation Summary
The owner was helping replace an alternator on a 2008 Chevrolet Equinox Sport after the serpentine belt had already been cut off. They were unsure whether the belt path went around a lower motor mount. The expert explained that the 3.4L and 3.6L use different routing and, for the 3.6L, the right-side engine mount bracket must be removed to install the belt. Routing directions and a diagram were provided.
