Will not start, how to test if relays are good or not having issues with anti-theft lock mode?
1998 FORD F-150
350,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
AMANDA78
How to test if relays are good or not having issues with anti-theft lock mode and do not have key to be insert into door. truck will not start checking relays as there were two blown fuses.
Jul 10, 2024 at 5:55 AM
  • 110,244 POSTS
A car relay is nothing more than an electrically operated switch that uses an electromagnet to mechanically close or open its contacts. Here’s how it works.
When an electrical current flows through the relay's primary coil, it creates a magnetic field around the coil. This magnetic field attracts an armature or iron core within the relay, causing it to complete the secondary portion of the relay. When the contacts close, they complete the circuit for another electrical component.
As far as testing, here is a link that explains how to check both a relay as well as the relay circuit. Take a look through it and let me know if it helps.
Let me know if that helps.
Jul 10, 2024 at 12:28 PM
