I hope you can help me with this problem. I have a VUE that was in a recent minor fender bender, driver's side headlight and bumper damage, no internals, ie, battery or frame damage.
I took it into the repair garage and they replaced the headlight and assembly, the bumper, and left fender.
I had it home a day and the battery was dead. Put in new battery and I get a ck engine light. The code calls out P1640, Output Driver Control Module 1/A Circuit Low Input. what could be the problem? Do you think a relay is bad, or loose connection. I just need a good place to start. It also breaks out to low coolant, ATFTemp Lamp circuit. Could this be a radiator sensor that is damaged or missing? Any help is appreciated.
Dec 17, 2009 at 9:03 AM
