2001 Saturn SL2 EVAP code P0452
SATURNTECH9
  • 30,869 POSTS
Unplug the connector's to the computer and see if there still connected that will eliminate the computer.
Friday, October 1st, 2010 AT 3:53 PM
KEVINMA255
  • 15 POSTS
Return voltage to computer (green wire) was 1.5 with about 2 gallons in the tank and was 1.48 after filling the tank then driving about 40 miles. ( The tank is still basically full.
Voltage to grey wire maintained 4.98 regardless of time it was checked. Orange/black is still a good ground signal.
Saturday, October 2nd, 2010 AT 3:13 PM
SATURNTECH9
  • 30,869 POSTS
The return voltage is what the computer read's with no pressure in the tank gas cap off it should read 1.2-1.5 volt's that is a normal reading. So far so good sounds like with those reading's.
Saturday, October 2nd, 2010 AT 3:39 PM
KEVINMA255
  • 15 POSTS
That sounds like the presure sensor is doing what it is suposed to. That to me indicates even more towards the computer. A computer is around $600 then I have to get it programed for the vin so I am sure that will be expensive. I will still plan on having somone hook it up to better equipment but I was hopping you would say the signals should be.1 at empty and 5 at full. I never get that lucky. Thanks for getting back to me on a saturday
Saturday, October 2nd, 2010 AT 4:20 PM
SATURNTECH9
  • 30,869 POSTS
The fuel level has no bearing on the pressure sensor reading. What effect's the reading is the vacuum level in the gas tank. If your going to throw a computer at it please don't spend all that money on a new one get a used one there a lot cheaper and already programed. You could probably find one for like 50 I would go for a used one if it was my car. The computer's hardly ever fail on those car's.
Saturday, October 2nd, 2010 AT 8:08 PM
KEVINMA255
  • 15 POSTS
I'm not going to throw a computer at it. I will have someone that can get live data to check it out before I do any more.
If it does need a computer I can get a junk yard one but still have to have someone flash it with the correct VIN and mileage. NJ inspection is now just a matter of type the vin into a computer and plug the OBD 2 port in. All sensors read good and the data matches, then you pass. Anything disagrees or fails you don't.
I just don't see how the computer could have coincidently gone bad at the same time a chunk of asphalt decided to jump up and dent a floor-pan, stretch a fuel line and snap a EVAP line. I don't doubt it, I just don't see how they are connected.
Sunday, October 3rd, 2010 AT 7:46 AM
SATURNTECH9
  • 30,869 POSTS
So when you hit this chunk of asphalt did it start setting this P0452 from that point on?It sound's like you more then likely just have a couple of wire's shorting together from what you have tested. Like I said the computer's don't fail often.I don't remember the mileage being stored in that model saturn the vin but not the mileage. The mileage is stored in the bcm.
Sunday, October 3rd, 2010 AT 11:06 AM
