If the battery is completely dead, and the alternator is NOT charging, this will happen. Sounds like you have a charging problem. Disconnect the battery and charge it real good. Like all day and night if you have a charger that will charge at 2 amps. Once you get the battery charged completely, see if it will start the car and stay running. If so, at that time, connect a DVOM to the battery and see what the alternator is doing. It should be in the low 14's (volts) maybe upper 13's. IF not, there's your problem.
SPONSORED LINKS
Saturday, October 25th, 2008 AT 12:43 PM
