1997 Saturn SL2 Car will not start
VHGRANT1957
  • 1997 SATURN SL2
  • 4 CYL
  • 135,173 MILES
Car will not turn over. Not the battery, light, car door alert on. Could it be the starter or spark plugs
Friday, June 11th, 2010 AT 6:08 PM
Did you meant it cranks over and will not start or just wont' crank over nothing at all when you turn key to starting position?
Friday, June 11th, 2010 AT 8:13 PM
VHGRANT1957
Its makes a clicking noise but will not start.I hope I am clear enough. Lights work, radio and inside light. Its not the battery.
Friday, June 11th, 2010 AT 8:55 PM
Clicking and starter not engaging engine could be one of the following:
No crank at all/nothing/nada:
Could be a blown fusible link the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good, disregard if it doesn't apply
Friday, June 11th, 2010 AT 9:35 PM
