1996 Saturn SL2 starting the car
JPHARP
  • 1996 SATURN SL2
  • 4 CYL
  • FWD
  • MANUAL
  • 134,000 MILES
The car is trying to start and when you put your foot to the floor it finally starts up. Why is it having problems starting
Wednesday, March 10th, 2010 AT 9:44 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like a bad coolant temp sensor that's screwed into ur head below where ur upper hose goes on to the head. There's two wire going to it a yellow one and a black one. When u remove the connector look and see if it's corroded if it is u will have to replace the connector. Make sure the car is cold and u will loose coolant. The sensors crack and leak coolant into the connector. If u replace the sensor make sure u get a brass tipped one the plastic tipped ones crack. There under 20 and that's ur best bet for ur starting concern. Let me know what u find.
Wednesday, March 10th, 2010 AT 10:27 PM
